1995 timing cover mod to work with newer HPOP without drainback issues
I thought I would post this for those that are interested.
This mod is for those of us with 1994 and 1995 strokes that want to install a new SD HPOP. Most of us that have done this have experienced HPOP reservoir drain back issues that result in hard starts after 2 or more days. One way to fix this is to modfiy the existing 1994 or 1995 timing cover to work with a new HPOP reservoir from a 1996 or newer engine.
The HOW_TO can be seen here
I will try to update any errors I find and add part numbers if I can as time goes by.
Special thanks to Rich (95F450SD) who was behind the original idea.
Good luck everyone!
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
