Re: 1995 timing cover mod to work with newer HPOP without drainback issues
radar--when you drill thru--shavings inside engine????? know how to stop it--hook up vacuum cleaner to engine--with the pressure side of the vacuum cleaner--can do this with a lot of them--wont have tons of pressure--but when drill thru--will blow chips out the hole--be sure to wear glasses!!!!!!!!!!! hook it to the oil fill hole--or have someone hold the hose over that spot when just about to punch thru-----
