Re: No power to 12V constant pin
Jeff,
I replaced the relay with a jumper to get a constant 12 volt feed to the "+" terminal of the 7 pin plug. I made the jumper from a piece of heavy guage wire with spade terminals on each end. I used a test light to determine where to plug it in. I'd have to check to see which two terminals I plugged into. On my 2000, the trailer charge relay and trailer backup light relay are in a small box with a lid, right next to the main power distribution box under the hood. It's the relay toward the front of the truck. I would think your '01 would be the same but don't know for sure [img]/ubbthreads/images/graemlins/shrug.gif[/img]. This is a pretty simple mod to get a constant 12V to the rear of the truck.
Hope this helps...
Dan
My Truck Pics
2000 F-350 Lariat 4x4 Crewcab longbed dually PSD 6 speed with: DP Tuner F5 16-pos. chip; Ford AIS air intake with fender sleeve & Zoodad mod; ITP boost regulator; fumoto valve; DPPI MBRP 4" turbo-back "cool duals" exhaust and 5x18 ITP stainless tips; Triple gauge A-pillar with Isspro EV gauges; "wicked wheel"; AIH delete plug with code eliminator and boost hookup; intercooler foil wrap removed; LED taillight mod, clear headlights, corner lights, cab lights, & dually fender lights; front-mounted 2" receiver, Putco Bossboards; Pace Edwards rolltop tonneau; acetoned badges; rear vision camera & reverse sensors; KC backup lights; C-Betr mirrors; cab lights & fender lights wired as turn signals; LED ID bar; Jordan 2020 Ultima trailer brake; harpoon mod; and more
