Diesel Forum - TheDieselStop.com - View Single Post - No power to 12V constant pin
Old 10-29-2006, 09:17 PM   #10 (permalink)
khokhonutt
Re: No power to 12V constant pin
Jeff,
I replaced the relay with a jumper to get a constant 12 volt feed to the "+" terminal of the 7 pin plug. I made the jumper from a piece of heavy guage wire with spade terminals on each end. I used a test light to determine where to plug it in. I'd have to check to see which two terminals I plugged into. On my 2000, the trailer charge relay and trailer backup light relay are in a small box with a lid, right next to the main power distribution box under the hood. It's the relay toward the front of the truck. I would think your '01 would be the same but don't know for sure [img]/ubbthreads/images/graemlins/shrug.gif[/img]. This is a pretty simple mod to get a constant 12V to the rear of the truck.
Hope this helps...
Dan
If you could check which terminals you jumped, I'd really appreciate it. I checked and the 'relay' is in the same place as where you describe (only the relay is not there). I'd like to get a relay at some point, but for now, jumping the terminals would work for what I need this coming weekend.
Thanks again,
Jeff
khokhonutt is offline   Reply With Quote
