Diesel Forum - TheDieselStop.com - View Single Post - No power to 12V constant pin
Old 10-30-2006, 10:22 PM   #15 (permalink)
D_Dunn
D_Dunn's Avatar
My Photos: (28)
Re: No power to 12V constant pin
Jeff,
Just remember that the reason that I replaced the relay with the jumper was to get 12V to the pin when the key is off. As Tobi mentioned above, the pin will be hot only with the key on if you install the relay. I pull a trailer for our local high school marching band too and it's nice to be able to use the lights without having to have the key on. Just so you know...
Dan
My Truck Pics
2000 F-350 Lariat 4x4 Crewcab longbed dually PSD 6 speed with: DP Tuner F5 16-pos. chip; Ford AIS air intake with fender sleeve & Zoodad mod; ITP boost regulator; fumoto valve; DPPI MBRP 4" turbo-back "cool duals" exhaust and 5x18 ITP stainless tips; Triple gauge A-pillar with Isspro EV gauges; "wicked wheel"; AIH delete plug with code eliminator and boost hookup; intercooler foil wrap removed; LED taillight mod, clear headlights, corner lights, cab lights, & dually fender lights; front-mounted 2" receiver, Putco Bossboards; Pace Edwards rolltop tonneau; acetoned badges; rear vision camera & reverse sensors; KC backup lights; C-Betr mirrors; cab lights & fender lights wired as turn signals; LED ID bar; Jordan 2020 Ultima trailer brake; harpoon mod; and more
D_Dunn is offline   Reply With Quote
