Re: No power to 12V constant pin
Jeff,
I replaced the relay with a jumper to get a constant 12 volt feed to the "+" terminal of the 7 pin plug. I made the jumper from a piece of heavy guage wire with spade terminals on each end. I used a test light to determine where to plug it in. This is a pretty simple mod to get a constant 12V to the rear of the truck.
Hope this helps...
Dan
The reason Ford uses the relay is to keep someone from leaving something on in the trailer/camper and draining your batteries. If you hard wire it, you can end up with dead battries [img]/ubbthreads/images/graemlins/blush.gif[/img] if you are not real careful. If the band trailer is the only aplication you have that pulls current from that pin you are probably ok but if you have other trailers/campers with a 12 charge/acc connection you may get yourself in trouble with always hot.
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
