Re: No power to 12V constant pin
Jeff,
I replaced the relay with a jumper to get a constant 12 volt feed to the "+" terminal of the 7 pin plug. I made the jumper from a piece of heavy guage wire with spade terminals on each end. I used a test light to determine where to plug it in. This is a pretty simple mod to get a constant 12V to the rear of the truck.
Hope this helps...
Dan
The reason Ford uses the relay is to keep someone from leaving something on in the trailer/camper and draining your batteries. If you hard wire it, you can end up with dead battries [img]/ubbthreads/images/graemlins/blush.gif[/img] if you are not real careful. If the band trailer is the only aplication you have that pulls current from that pin you are probably ok but if you have other trailers/campers with a 12 charge/acc connection you may get yourself in trouble with always hot.
Rubystargoats,
I am aware of that, but I appreciate your concern. I have three different trailers I pull, and none have a charging system. I used to have a 5th wheel which did, but we sold it last year [img]/ubbthreads/images/graemlins/frown.gif[/img].
Dan
My Truck Pics
2000 F-350 Lariat 4x4 Crewcab longbed dually PSD 6 speed with: DP Tuner F5 16-pos. chip; Ford AIS air intake with fender sleeve & Zoodad mod; ITP boost regulator; fumoto valve; DPPI MBRP 4" turbo-back "cool duals" exhaust and 5x18 ITP stainless tips; Triple gauge A-pillar with Isspro EV gauges; "wicked wheel"; AIH delete plug with code eliminator and boost hookup; intercooler foil wrap removed; LED taillight mod, clear headlights, corner lights, cab lights, & dually fender lights; front-mounted 2" receiver, Putco Bossboards; Pace Edwards rolltop tonneau; acetoned badges; rear vision camera & reverse sensors; KC backup lights; C-Betr mirrors; cab lights & fender lights wired as turn signals; LED ID bar; Jordan 2020 Ultima trailer brake; harpoon mod; and more
