Diesel Forum - TheDieselStop.com - View Single Post - Fuel Filter/seperator drain o-ring replacement...my first write up
Old 10-30-2006, 06:23 PM   #1 (permalink)
joedirt
joedirt's Avatar
[moderator's note] The photo links in this post are broken, but one of the members (his one and only post) put together a PDF of this post with the photos here: http://www.thedieselstop.com/forums/f47/fuel-filter-seperator-drain-o-ring-replacement-my-first-write-up-125558/index13.html#post1484534
[/end note]
well,...mine started leaking last week....noticed the raw fuel smell and diesel on my front axle....
went to ford and they wanted close to $40 for a "kit"...so i searced around locally and found some 1/2"od x 1/4"id x 1/8" thick orings from a place called filter services in se portland....payed $.30 for both...
on with the tech....
find the tube on the passengers side block......
drain tube
thats the drain tube........hook up a hose long enough to reach a bucket (so it dont just dump fuel right onto the ground and make a mess).....
hose placement
remove the cover that goes over the fuel filter housing (this is a good time to replace the filter).....
filter cover
removed......
cover removed
find the drain valve behind the filter housing and move the yellow lever to the right to drain the fuel from the filter housing.....
yellow lever
lever turned and draining
this is where the bucket and hose comes in handy......
bucket
let it drain completely,...then your ready to pull it apart....heres what i used.....allen style torx bit.....this is a #20 torx.....this seemed alot easier than a bit in a 1/4" drive ratchet,...but use whatever works for you,...its very tight back there.....
#20 torx
once removed,...take the assembly to a clean dry place and remove the old o-rings from the back of the valve.....
removed...
o-ring comparison.....
i used a pick tool to remove the old o-rings......to install the new ones,...just push them into place and they will fit like a glove
o-rings installed
now just put it back together and remove hose and discard of the fuel properly.....
before cranking it up right away,...get in and turn the key and wait for about 60 seconds for the fuel pump to fill the filter housing back up....
done!!
1994.5 f250 powerstroke, 4" exhaust straight piped, 5-speed, tymar, edge ez, standard cab
joedirt is offline   Reply With Quote
