Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Mine hasn't started to leak yet but just like the spare cps I'm getting prepared. Where'd you find allen wrench style torx bits?
I used a torx bit from a screwdriver and a 1/4" socket to fit it into, although I think Sears and other stores would have something like that already made up. I know you can get socket wrench allen bits.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
