Diesel Forum - TheDieselStop.com - View Single Post - Fuel Filter/seperator drain o-ring replacement...my first write up
Old 02-01-2007, 12:19 AM   #132 (permalink)
dp3572007
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
FYI while on vacation in colorado my fuel seperator valve o- rings started bypassing diesel straight to the ground. I was about thirty miles from Golden co at the time with no auto store around. I removed the metal line from the back of the short rubber hose on the valve and plugged the rubber hose with a 5/16 bolt and 2 small hose clamps. I then drove to the ford house in golden with no leakage from the valve. I put the new valve on in the parking lot, not knowing I could have bought just the o-rings, could have save about 28 bucks lol. They charged me 65.00 for the valve. You know on vacation you do what u have to do.
thanks for all the info on these forums, there are alot of knowledgeable people on here.
99 F250SD 153000 miles HD AIS other than that STK all the way
dp3572007 is offline   Reply With Quote
