Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Sure. [img]/ubbthreads/images/graemlins/smile.gif[/img]
F81Z-9C065-AA O-ring seal kit includes 5 O-rings....
2 each - Fuel Drain - These are Black, coated with a Yellow material.
1/2" OD X 1/4" ID X 1/8" CS
1 each - Water In Fuel Sensor (larger O-ring) - This is Green.
1/2" OD X 5/16" ID X 3/32" CS
1 each - Water in Fuel Sensor (smaller O-ring) - This is Brown.
3/8" OD X 3/16" ID X 3/32" CS
1 each - Fuel Pressure Relief Valve - This is Green.
15/16" OD X 3/4" ID X 3/32" CS
If your little black plastic Water In Fuel Sensor (WIF) is leaking through the spade, it is F81Z-9J294-BA...about $130.00 at $Ford$. For some reason Ford also calls it an external heater. But -AA is the actual heater inside the bowl.
