Diesel Forum - TheDieselStop.com - View Single Post - Fuel Filter/seperator drain o-ring replacement...my first write up
Old 03-06-2007, 02:59 PM   #155 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Thanks Gooch,
So Ford actually DOES sell the fuel drain o-rings. Just in a kit with wif sensor and regulator o-rings as well.
I have a suspicion that the yellow coating is teflon. There to make the valve a little easier to turn. I could be wrong, but it makes sense.
Hard or no-start? Check Here
