Diesel Forum - TheDieselStop.com - View Single Post - Fuel Filter/seperator drain o-ring replacement...my first write up
Old 03-06-2007, 08:04 PM   #158 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Fuel Filter/seperator drain o-ring replacement...my first write up
Vibra-lock sleeves are 1/4" for the individual fuel lines to the heads and 5/16" for the main supply line to the filter. I think the return line is also 5/16" or maybe 3/8". I just have a handful of each size.
Gooch, I know what you mean about prices. I'll check Int'l to see what they get for them next time I get by there. Other o-rings I've bought there have generally been under $1 each.
o-ringsusa.com gets 50c each plus 75c each for teflon coating (must be confusing gold for yellow [img]/ubbthreads/images/graemlins/smirk.gif[/img]). I've thought about getting some of those, but haven't gotten around to putting together an o-ring order yet.
Thanks again
Hard or no-start? Check Here
