Diesel Forum - TheDieselStop.com - View Single Post - Fuel Filter/seperator drain o-ring replacement...my first write up
Old 03-22-2007, 09:33 PM   #162 (permalink)
BigDogMK
Re: seperator o-ring replacement...my first write up
All:
I changed my O-rings tonight. It was not a 1 hour job...not for an old man with big hands. I found that by removing a couple of connections on the manifold behind and just above the fuel filter housing that I could gain a few precious centimeters of clearance. And, can you believe the number of sharp edges on the back side of the fuel filter housing? My hands feel like they've been in a meat grinder. But....we no leaky now!
Somewhere in here someone mentioned an old diesel trick of adding a little oil to each tank of fuel for extra lube. I've started adding a pint of 2 stroke injector oil to every fill up. Don't know if it'll help keep my seals fresh, but it's worth a try.
BigDogMK
2000 F250 SD Supercab 4x4 SB, Weld wheels, BFG 33x12.50x16.5 tires, Ford Severe Duty AIS, auto, LanceLite 845 slide-in camper w/Tork Lifts, air bags, 3.73 posi, red/tan. 171K and counting.... Edge Evolution, 4" DP and exhaust, DiPricol pyro and trans temp guages on the A-pillar, Bilstein shocks, Putco Boss Bars, 6.0 trans cooler, heater bypass valve.
Repairs: ball joints, front brakes, rotors, calipers, front brake hoses, 2 CPSs (and counting), alternator, rear pinion seal, fuel filter housing gaskets, rear brake pads, left rear brake line, Weld wheel failure, batteries.
BigDogMK is offline   Reply With Quote
