Diesel Forum - TheDieselStop.com - View Single Post - Fuel Filter/seperator drain o-ring replacement...my first write up
Old 04-24-2007, 10:37 AM   #165 (permalink)
arisley
Re: seperator o-ring replacement...my first write up
I cut a piece of rubber made a gasket and completely sealed off the drain, use the same method to drain and replace filter.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline   Reply With Quote
