Re: Trailer? Chip? Wiring? What happened???
I had a Superchip and it worked fine for years. I made sure that the contacts were extra clean as I completely removed the card from the CPM to clean it.
I have not sed this trailer in over a year. I went out last evening and found that the lights were completely messed up. No running lights at all. Right taillight is on brake, left tail light barely visible and blinks when I turn the right blinker on. What a mess. The wife had a friend barrow the trailer last year and they ground the plug down dragging it as they did not have a 7 pin connector (I had the adapter if I knew what they were trying to do.
It is -5F today...if it warms up I will re installed the 4 position chip and see how the truck runs...prior to towing it worked fine. If all is well, I wiill haul a different trailer and see if it does it again (one that I know has good wiring). I will let the forum know what I find. What bothers me is that the tranny did fine (and TC) when I have the chip out, only acts up with the chip while pulling this trailer. Hmmmmmmmmm [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'97 F250 XLT, PSD, Ext Cab, E4OD, 4.10, TYMAR 4 position flip CHIP, BD Downpipe, Isspro pyrometer pre-turbo, AutoMeter tranny gauge, info@TymarPerformance.comTymar air, Tymar coolant filter, and Tymar HPX mod, ported wind deflector, 4" Exhaust, 4" kitty, Hayden tranny cooler w/in-line magnetic filter, Sonnex Valve, Tricumulator Springs, BMM tranny pan Summit Racing, Synthetic ATF, DYNAMAT, AC Mod, Bilstein Shocks from Eshock, Joe Servo IDM Mod, rhino bedliner, custom wheels, Lil' Rocker 5er hitch, 26.5 Prowler LE
RALLY
