Re: Dexter 9000lb Axle Question
Don't know if there is one available for this size but the seal surface can be replaced with a ring that slips over the damaged area. Then a seal with a larger ID is used. I'm trying to remember where I've seen this and I think that it was for a tractor trailer drive axle. Cheap too!
On edit: You might contact Dexter, they may have the repair ring available.
Good Luck,
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
