Re: Air Filter
I have a 05, gotta love it.
Check the filter minder attached to the filter intake tube. Don’t know about the 06’s; but on the 05, there is a warning light that tells you the filter is clogged.
The stock filter is a good filter may last you a while longer. I’d wait till its time to change the filter before installing after market. The stock filter is pricey and why wast a good filter
I run afe. I have the afe yellow colored pro guard 7 for off road use and the afe blue filter for street use, I do a lot of off roading in the summer.
The stock filter is a 1-micron filter.
The yellow filter is a 1-micron filter with twice the airflow of the stock
The blue filter is a 3-micron filter with 3 to 4 time the airflow over stock. Yellow will improve performance the blue will give you the best performance. If your not in the dirt allow go with the blue.
05 F350 S/D Crew Cab 6.6'bed. Blk on Blk fX4, Up-fitter Switch Tow Command, Tow haul, Backup Sensors, Tow package upgrade, Crews Control, Keyless entry, & Base alarm. Dual Alternators/ Batteries, Sunroof, Electric Rear Window, 6-CD player, Full Electric Seats. 4inch lift, 18-inch polished aluminum wheels. Spray on bed liner & rubber bed matt.
Remote Start & Alarm, Entertainment Center, GPS & XM. External 12-volt power, Customized TracRac system with Yakama Road Warrior Rack and 520watts roof mounted off road lights. Adjustable tie down mounts on both side of the bed.
Extra 12-volt power in the cab, 3-gauge mirror mount, Trans temp, fuel & oil pressure. Rear air bags with onboard air compressor-in cab gauge & controller, plus more.
