Re: Air Filter
If you want to read a completed thread on this subject, do a search using
“Should I install an aftermarket intake?” it' on page 7
The air filter question was dissected and picked apart and a conclusion reached. If you want the short version, use the following links. sorry cant get them to hyper-link you need to copy & paste.
Dyno charts:
http://www.afefilters.com/images/54-10392.pdf
http://www.afefilters.com/54-11022pr.htm
http://www.afefilters.com/images/54-11022npa.pdf
http://www.afefilters.com/images/54-11022HP.jpg
05 F350 S/D Crew Cab 6.6'bed. Blk on Blk fX4, Up-fitter Switch Tow Command, Tow haul, Backup Sensors, Tow package upgrade, Crews Control, Keyless entry, & Base alarm. Dual Alternators/ Batteries, Sunroof, Electric Rear Window, 6-CD player, Full Electric Seats. 4inch lift, 18-inch polished aluminum wheels. Spray on bed liner & rubber bed matt.
Remote Start & Alarm, Entertainment Center, GPS & XM. External 12-volt power, Customized TracRac system with Yakama Road Warrior Rack and 520watts roof mounted off road lights. Adjustable tie down mounts on both side of the bed.
Extra 12-volt power in the cab, 3-gauge mirror mount, Trans temp, fuel & oil pressure. Rear air bags with onboard air compressor-in cab gauge & controller, plus more.
