Re: Air Filter
On the same subject, I have been trying to find a after market airflow sensor and gauge set up to monitor airflow past the filter. I have had no luck. Is there such a critter, if so, where can I get one?
05 F350 S/D Crew Cab 6.6'bed. Blk on Blk fX4, Up-fitter Switch Tow Command, Tow haul, Backup Sensors, Tow package upgrade, Crews Control, Keyless entry, & Base alarm. Dual Alternators/ Batteries, Sunroof, Electric Rear Window, 6-CD player, Full Electric Seats. 4inch lift, 18-inch polished aluminum wheels. Spray on bed liner & rubber bed matt.
Remote Start & Alarm, Entertainment Center, GPS & XM. External 12-volt power, Customized TracRac system with Yakama Road Warrior Rack and 520watts roof mounted off road lights. Adjustable tie down mounts on both side of the bed.
Extra 12-volt power in the cab, 3-gauge mirror mount, Trans temp, fuel & oil pressure. Rear air bags with onboard air compressor-in cab gauge & controller, plus more.
