Re: What not to do with your Ford!!
The hitch didn't break. The trailer popped off the ball or the pintle was not locked down.
No biggie. We have had that happen to us at our marina once or twice.
We also have had our hitch break off with our hydraulic trailer. Hitch looked like it had a crack for a long time. Broke right off going down the road, trailer dug right into the pavement and came to a abrupt hault in the middle of the road. Thankfully no boat on.
