Re: for the Tech's & exhaust brake
The brake will only cause problems if you were to leave it on 100% of the time. Once the brake is opened and you get on it you clean out any build up. I installed one on a customers truck and it worked well.
Tadd
Elite Diesel Custom Tuning www.elitedieseleng.com
tadd@elite-diesel.com
1-866-631-8518
Elite Diesel SCT Tuning for 6.0 and 7.3's with Cylinder Pressure Adjusted tunes, Programmers or 6-position chips, Custom 6.0 Injectors, 2 Stages of 6.0L Fuel Systems, H-11 Head Studs, Fire Ring Kits, Single and Compound Turbos for the 6.0L, Engine Internals
04 F350 XLT SPORT CC DRW
Elite Diesel SCT Tuner,AFE Stage 2, 345cc Injectors, 6" Stacks, S400 turbo. 701hp on #2
Look in the september issue of Diesel Power Mag.
Ford Senior Master Technician
