Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 12-03-2006, 07:08 PM   #1 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
I imagine that you guys down here in the basement are having troubles with fuel leaks like the superduty crowd is. I just posted some photos that may help out with this.
Here's some pix of a 94-97 van filter drain valve.
Fix your fuel leak from filter drain valve-o-rings_removed_-_valve_in_closed_position.jpg
Or you can go to my album that has more pix (hit the max of 5 inserted in a post) and some notes about disassembling the valve.
94-97 Fuel Drain Valve - TheDieselStop.Com Photo Hosting
Hard or no-start? Check Here
Last edited by klhansen; 04-10-2008 at 11:04 PM. Reason: Replaced broken link with direct link to photos
