Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 02-19-2007, 12:21 AM   #8 (permalink)
Sabre2th
Sabre2th's Avatar
Re: Fix your fuel leak from filter drain valve
If you decide to replace the o-ring on the top of the valve stem at the same time, it is a -013 o-ring...
Just my .01
Tom
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
Drain valve repair write-up with pics
Sabre2th is offline   Reply With Quote
