Re: Fix your fuel leak from filter drain valve
ok i know where the 2 torx tip screws are and i have my o-rings in hand. my question is do i have to remove my filter bowl or can i somehow get to the 2 screws for removing and installing. it looks tight because it is at the bottom of the bowl. thanks
Sorry I can't tell you, as I've never done the job on an OBS truck, just borrowed the filter bowl from a buddy to take the pix.
There's one sure way to find out, and that's dig in and try it.
Post what you find out here, so other folks will know.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
