Old 03-22-2007, 04:49 PM   #11 (permalink)
wedge542
Re: Fix your fuel leak from filter drain valve
If you got super small extra long fingers and they can bend in several areas at once then you might be able to but if not,take the rubber line lose on back of filter can to pump,take lose the line on the right side of the filter can,look in back of filter at very bottom youll see two metric bolts holding it down,take out,now youll be able to move filter can around some,not much but enough to get a t15 torx socket on,break lose then use fingers to turn socket till out a bit,then use just fingers to completly remove little torx screws,the handle comes off with it once its lowered alittle,,the newer valves have 4 torx screws and want work on older 94s,take your time,if you drop anything youll need a small magnet to fish it out.
wedge542 is offline   Reply With Quote
