Diesel Forum - TheDieselStop.com - View Single Post - ULSD Fuel
Thread: ULSD Fuel
Old 03-09-2007, 12:58 PM   #33 (permalink)
nlemerise
Re: ULSD Fuel
If you are concerned about lubricity of the new ULSD, check out the chart below. Basically, you can obtain all the lubricity needed with as low as 2% biodiesel. I run 5% biodiesel and the truck loves it!
biodiesel wearchart
1999 F-350 - CC/LB, gauges, 40K trans-cooler & external filtration & drain, 203 t-stat mod, Mag-Tech Trans & Diff. cover, AIS filtration, zoodad, HPO x-over, Jody Tipton 40HP tow PCM, Hutch mod and harpooned, Baldwin prepump fuel filter
"Better to be judged by 12, than carried by six!"
nlemerise is offline   Reply With Quote
