Diesel Forum - TheDieselStop.com - View Single Post - ULSD Fuel
Thread: ULSD Fuel
Old 04-09-2007, 01:56 AM   #40 (permalink)
rms0726ea
rms0726ea's Avatar
Re: ULSD Fuel
I've heard of using tranny fluid to lubricate and also help clean the motor. How much would be appropriate to use? Anyone know?
The use of automatic transmission fluid will not only raise the sulfur content of the diesel fuel significant but it also can cause the formation of injector deposits and fuel system deposits as the fuel is burned. These deposits can cause poor spray patterns, incomplete combustion of the fuel and increased emissions.
You will probably notice a slight decrease in fuel milage since the BTU level of ULSD fuel is lower than the LSD.
Schaeffer's Diesel Treat (http://www.schaefferoil.com/diesel_treat_2000.html) 1 gallon container treats 2000 gallons compared to power services' 3/4 gallon container which only treats 300 gallons.
www.totaldieselperformance.com, Tony Wildman 4 pos chip, 2003 7.3L F250 Lariat, Swamps 175/146 single shots, MBRP exhaust, AIS w/fender sleeve & Zoodad, ISSPRO A-pillar 3 gauge kit(pyro/boost/tran temp), DiPricol HPOP & Fuel, oilguard bypass filter, CCV mod, extreme duty tranny (by Jon Faubion-Richter69), BTS (PI) Torque Converter, AIH delete, 6.0 trans cooler, van turbo w/wicked wheel, Gutted EBPV, DI Intercooler, ITP Overboost Kit , HX mod, Bilstein Shocks, Firestone Ride-Rite air bags w/compressor, Dieselsite Coolant Filter, Schaeffer's 15W-40, ITP in tank mod/pre-pump filter, Harpoon mod
rms0726ea is offline   Reply With Quote
