Re: Alternator question
I'm always at 13.2 - 13.4 and thats with everything off or on. (Lights, aftermarket speakers, amp, radio, heat, you name it and its on. Same when everything is off.
Ok, if it checks out the same whether the other stuff is on or off, then you may have another issue. One thing I would check is the battery cable nearest your hot side IC tube (passenger side). When I changed out my alternator earlier this year, that cable had been rubbing on the IC tube. If yours is and has rubbed through, it might be affecting the alternator's ability to work right. If everything there checks out, then it's likely your alternator is fixing to take a dump on ya....
(BTW, I am running the amp in my sig, a Sirius Sportster 4 radio and a fairly high power CB on mine. My voltage according to my AIC is usually in the mid to high 13's while running down the road. At a stop light, it may drop into the low 13's... If that helps ya at all...)
 2003 Toreador Red/ Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
