Re: Weird door ajar problem
Very common problem.
It's the switch(es) inside the door latches. You can fix it up by spraying WD40 or PB Blaster into the latch opening in the doors (where it contacts the bolt on the door frame). That should free up the sticking switch.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
