Re: Weird door ajar problem
Mine was having the same problem with the door ajar/dome light (what was really annoying was the key in ignition chime if you didn't have the engine running). For a while, it was an intermittent problem that went away after driving a few miles, but lately it had been on all the time. I figured I would have to pull the door panel off, so I did a search for "dome panel" and found this post (Thankfully)! Sp today I sprayed some lube on the latch, opened and closed the door a few times and problem solved!!! Thanks guys.
-Brett
2001 F-250 Powerstroke, Automatic. Zoodad mod, Airaid filter, muffler delete, Boost fooler, Edge Evolution, Turbonetics 0.84 turbo. Best 14.88@88MPH, 314hp@617trq.
1989 F-250 7.3 IDI N/A, 5 speed, no muffler. Injector Pump turned up 145*.
