Diesel Forum - TheDieselStop.com - View Single Post - Weird door ajar problem
Old 03-29-2007, 09:04 PM   #10 (permalink)
dvtech
Re: Weird door ajar problem
i do alot of these. it not that hard to replace them. pull the panel,remove the 10mm bolt holding the window trk. at the rear portion of door. just pulls right out & will be out of the way. unplug the sw. at the inside portion of latch by pushing against it at the plugin till you hear it snap then pull it out of the latch. the trickey thing is getting it alighned in the hole going back & pull against it till it locks back in. we don't lube them here cause we don't want a comeback which it will give you trouble later. you may have to loosen the 3 screws that hold the latch the dorr to get enough room to turn it all the way in to remove it. depends on what model you have & body style.takes me about 15 mins to replace one. the panels are a snap to come off. thats what i like about them.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline   Reply With Quote
