Re: Weird door ajar problem
i do alot of these. it not that hard to replace them. we don't lube them here cause we don't want a comeback which it will give you trouble later. That's what i like about them.
Please don't take this the wrong way but I can't see all this simple work and parts costs when a 2 second spray of WD40 fixes the problem. As far as the comeback, I did mine over a year ago and still no problem. Took me less than a minute and cost me about $.05 of WD40.
I ran into this problem with the owner of the marine dealership where I worked as a mechanic. Push/pull light switches usually quit working from corroded contacts. Replacing one usually meant cutting off the spade terminals on the wires and replacing with ring terminals to match the new switch. Not me, I'd remove the switch and disassemble it. Then I'd hit the slider plate and contacts with the wire wheel and reassemble the switch with a dab of anti-corrosion grease. Took a fraction of the time over installing the new switch and I never had a comeback. The owner however, felt that he was losing money on parts even though the labor savings made up for that and I did more billable work than the other mechanics.
My point of the above is that you may be just caught in the middle of an unsuspecting vehicle owner and a dealer that wants to sell switches.
CaptRon
