Diesel Forum - TheDieselStop.com - View Single Post - Weird door ajar problem
Old 06-29-2007, 09:36 PM   #28 (permalink)
dipper
Re: Weird door ajar problem
BUT... if your vehicle does not have the V.S.M. like mine then you can do what I did. Pull the door panel off, unhook the linkage from the latch mechanism and the electrical plugs, take out the 2 screws that hold the latch in and carefully manipulate it out and w/a wrench take the switch off the mechanism and spray a generous portion of the world famous WD-40 liquid gold and work the action of this switch for about 5 minutes repeatidly spraying, then re-install the switch, the mechanism, the electrical plugs, and the linkages, make sure it works properly by shutting and opening several times w/ the key in the ignition turned on and the window down. If all is well, no chime and no door ajar light, also dome light will go out. Now you can re-install the door panel. Taa Daa.
dipper is offline   Reply With Quote
