Re: head stud install ?
Powerstrokenstang,
If you are using ARP studs, make sure you put the 8 shorter studs on the top row of the heads. They are only 5-6mm shorter than the rest so you'll have to look close. If you dont, the top base of you injectors will hit the studs.
Joey,
My new engine is thirsty for OIL!!!!!!!
03/98 F250 7.3,4X4,CC,SB,AT, 3.73, bought totally stock in 10/05 w/111k miles, #5 Cylinder burned up at 114K ml.
Upgrades since then= BTS T/C & V/B, 6.0 cooler, Van turbo, DIESELSITE= Dahl 100, Coolant Filter, Boost Relief Valve. FS2500 oil bypass, AIS air filter, Di/Pricol Gauges EGT, Boost and Trans Temp, Magnaflow 4" Turbo-back, Wicked Wheel (org. was bad), Fabtech 3.5" leveling kit w/ track-bar, rear Hellwig sway bar, Weld 16.5x12, 35x12.5-16.5, CCV mod,
117k ml 3rd motor now
DP Tuner stock-40-80-120, ARP studs, ITP Regulated Return Kit, new stock 7.3 I/C.
http://community.webshots.com/album/551035547SsFoES
Criminals love gun control -- it makes their jobs safer.
