Diesel Forum - TheDieselStop.com - View Single Post - New little secrets thru 07/30/05
Old 04-17-2003, 09:15 AM   #1 (permalink)
Larry M
My Photos: (11)
*********************READ THIS FIRST*******************
There is a lot of information here and to speed up your access I have added a couple of features to this thread. You may scroll thru all the posts to find the subsection that you want and the title of each post has those subsections in the subject line in parans and here are the post titles in order including this post that has the A-B links:
New little secrets(A-B) ... this post
New little secrets(C-E)
New little secret(F)
New little secrets(G)
New little secrets(H-S)
New little secrets(T)
New little secrets(U-Z)
New little secrets(Misc.)
New little secrets (Cackle and Idle Knock links)
New little secrets(FAQs) thanks to TParker
An alternative is to simply CLICK HERE [link broken and not fixable] which will take you to this post in the threaded view and then scroll down to the listing of all the posts in this thead and click on the title of the post that you're interested in.
I started a thread HERE [link broken and not fixable] that had a grunch of links that I refer to and have been updating it periodically, but noticed it's getting long and taking a while to load so I'm starting this new thread with the latest info and will be locking the old one with a post linking to this new thread.
AIC/APCM
01/09/04 by gtspowerstroke: need AIC wire harness
Has part# for AIC wiring harness
01/18/04 by PonchoBrew: Ford Reprogrammer
Has link to AIC manual
Air Filters
05/10/02 by Robyn: Air Filter/AirBox Study at Banks: The Results Are In! Part 1
07/04/03 by BigRig250: Check you air filter!
07/05/03 by Larry M: Check your air filter ... Con't
Has my filterminder vacuum test results
07/17/03 by woodworker: Ford Intake Upgrade - Do We Need This?
Has comment from Jordan Flagstad from Donaldson on the AIS
08/01/03 by extreamTT: AIS and SCMT dont play well together
Good discussion of intake restriction with the results of my testing
08/16/03 by haul_n_horses2: Stock air box restriction
Good discussion of air restriction values
1/23/04 by Zilard250: Bad news for Tymer(dDonldson) users
02/05/04 by druz: 7.3 cranks takes 7 to 10 seconds to start. SOLVED SOLVED YEA YEA!
Has good discussion of Air Restriction
02/15/04 by powerstroke250: A I S SUCKS
06/01/04 by mike650: AIS Problems
Has post by AIS engineer on where the 25in H20 is measured
07/25/04 by cjheap: negative aspects of Tymar Filter
Has post with my Si using my Amsoil air filter
08/14/04 by cgrove: AIS OUT - Stock Back IN!
Has comments on where the max 25in H20 is to be measured for the AIS
08/26/04 by blez: What air filter???
Has good info on filter efficiency/restriction for some common elements
Air Intake Heater (AIH)
04/03/05 by JMS1: AIH resistor wire
04/21/05 by ForumBlue: AIH Delete??
05/15/05 by blowhard: AIH code
05/15/05 by MarvinVR: Removing Air Intake Heater Plug--smart or dumb?
05/27/05 by kawasaki150hp: AIH Delete Warning
07/30/05 by mthisguy: AIH delete question
Batteries
2/06/02 by JSP54: Change both or one battery?
2/09/02 by kodiac: Optima Batteries- Red Top or Yellow Top?
01/05/03 by Smiley: Batteries?
04/23/03 by platinumf250: Optima - Red or Yellow Top????
06/29/03 by The New Kid: Interstate 6-volt Golf cart batteries
07/07/03 by RockSalt: Optima Batteries for PSD??
11/28/03 by arnoldauto: Calling all Electrical EXPERTS...draw on battery (.186mA) lets pick some brains
Block Heater
11/05/03 by coloradodiesel: Woop's - Block Heater Plug Melted
Has link to fire damage photo
01/08/04 by Engineering_Student: What is The Power Consumption of The Engine Block Heater
02/01/04 by RC: Post Fire Pictures
Brakes
02/18/02 by StevePSD: Make sure you change your brake fluid!
01/23/03 by FishAlaska: Brake pad recommendations
03/05/03 by Harald: Pulsing brakes
06/06/03 by DENNY: Flushed the brakes! Fluid looked like coke!!
06/16/03 by rxbike: Help, I need new rotors, which are best ?
06/18/03 by jswillms: The Warped Rotor Myth
07/20/03 by fnelsonII: brake calipers and K&N filter
Has link for caliper slide grease
09/10/03 by tcnofh1: how to tell if my E-350 has Front or Rear or both ends ABS
11/19/03 by hank53: Bleeding brake fluid tips
01/04/04 by soaggydogg: Brake fluid... have you ??
06/19/04 by Bobcat698: Front Brake help, several questions.. Please help ASAP
Recommended brake pads
07/04/04 by joggerman: Emergency Brake
Good thread on adjusting and maintaining the EB
08/03/04 by bmw1200: Brakes and rotors, probably been discussed before
Has FMTRVT's recommendation on replacement pads
08/09/04 by Johnp034: ART Rotors or Performance Friction?
08/17/04 by 1BADF350: What is your thoughts on flushing your brake fluid??
Has link to Jack's post on when to change brake fluid
11/01/04 by jstrauss: Replaced my brake fluid - feel like I'm in bizarro world
11/29/04 by BigwheelStroke: Brakes??? What Should I Do?
Discusses the loss of braking when running oversized tires
12/07/04 by lwg: Brake Fluid type revisited..... Again
Has comment's by Jack on brake fluid types to use
04/10/05 by bekair: Q's for FMTRVT
Larry M is offline   Reply With Quote
