Diesel Forum - TheDieselStop.com - View Single Post - New little secrets thru 07/30/05
Old 04-17-2003, 09:19 AM   #2 (permalink)
Larry M
My Photos: (11)
Re: New little secrets(C-E) thru 07/30/05
Here are the C thru E Links
Larry
Cackle
12/19/01 by diesel dave 99: MPG AND CACKLE
(grab a pot of coffee for this one, it's the grandaddy of cackle threads klhansen)
03/16/03 by JLester: New Cackle Thread Here [Continuation of the thread above - put on another pot. klhansen]
4/21/02 by beantown: Cackle wav anyone? Does yours cackle this bad?
4/22/02 by Larry M: Non knocker/cackler .wavs needed
5/07/02 by Bob Riley: My wave files at idle and 2000 rpms
5/09/02 by Arctic Cat Hauler: My fuel line theory AIR=BAD
5/20/02 by Larry M: Cackle and Idle Knock Links [links on this one most likely won't work]
5/27/02 by JOHNNYDCON: Appearance of knock/cacle theory
5/28/02 by CKing: Great Post on Rail Harmonics, My WAG solution to Cackle
6/03/02 by wkw: An Acoustical Study of Idle Knock
6/10/02 by DieselRay: Changing Harmonics of the Fuel Rail
6/13/02 by Larry M: Fuel rail geometry and injector dynamics
6/18/02 by h2o_dog: Please define "cackle" problem....
7/19/02 by POWERSTROKE RACER: Idle knock after any reg mod
01/05/03 by 1ton: Spark-Knock sound?
01/22/03 by jat99: Cackle observation-Give Feedback
02/26/03 by pwrstrokeme: Pat's air?
Has my definition of it and link to mpg thread
03/14/03 by DB: Going to Investigate Cackle Issues
12/17/03 by DB: Cackle Revisted
CCV system
03/16/04 by ElkChaser: CCV Mods/RacorCCV4500/Crankcase Pressures/Test Results
Charging System
03/13/04 by land_yaght: Wierd Charging Problem
04/20/05 by bigbore: 215 amp ambulance alt is in and running.
Cooling system Note: subsections in red
*******Warning read the thread by Smokey Wren on 12/18/03 for type of coolant to use since earlier threads than that will not have the most up-to-date information ******** , Thanks Larry
Cooling system - Coolants
5/31/02 by DeanC: Fleetrite coolant - need confirmed part no.
8/29/02 by flash1034: Power Stroke Coolant- Need Final answer please
12/16/02 by goalie: coolant question
02/02/03 by pjwarner: Evans Coolant
02/08/03 by JIMF250: coolant
02/21/03 by Wesman60: Which Coolant?
04/15/03 by Machinehead: Where can I find the correct Gold Coolant?
05/15/03 by CPSS: PEAK antifreeze from IH dealer
09/02/03 by Bwygans: Coolant ? Fleetrite
10/03/03 by Johnny_V: Is Evans worth the $200
Monster coolant discussion
10/13/03 by Lucca: Coolant Confusion
Good discussion of the Weatherpro coolant
12/18/03 by SmokeyWren: Gold coolant approved for all '99-up PSDs
12/25/03 by WRICH: coolant question
01/15/04 by 99psowner: Coolant
02/16/04 by ronk54: Verifying correct Motorcraft Coolant - changing it tomorrow
03/24/04 by TJC1989: Proof that Ford approves the Long Life Gold Coolant in PSD's?
Has Smokey's answer on Gold approval
04/05/04 by tcnofh1: purple Allied coolant????
04/11/04 by RootDoc: Coolant Color
07/09/04 by DizzyD: got my ZEREX 5-100 & FOMOCO additive......
Has link to pics of what the G-05 looks like
07/15/04 by Seanpatsdad: Question for Smokey about Green Coolant
09/22/04 by Larry M: Going for the GOLD
Has pics/links and part # for the Zerex G-05 coolant
11/20/04 by Y2KPSD: Smokey - Green or Gold
12/04/04 by legends13: another coolant question
Comments on not using ELC coolants
12/09/04 by mwierowski: Coolant question
03/25/05 by bradyr: Shell Rotella Coolant - Is it OK?
04/01/05 by F350FINALLY: Rotella ELC or Evans? Where to buy?
04/03/05 by Larry M: *****MORE FUN - Coolant Survey Version Two*****
04/28/05 by rockycarl: Parts stores no longer sell our GOLD COOLANT...they sell a new product by Prestone!
5/14/05 by glarestop: ROTELLA ELC COOLANT: RED ! OK FOR PSD ???
07/23/05 by BunnMan: extended life coolant revisitted
07/27/05 by jimzpsd: ROTELLA ELC 50/50 Coolant
Has a good post by Tim Miller on his ELC coolant leak issue
Cooling system - Additives/Testing
8/24/02 by m bullock: Why do diesels cooling systems need F16 and not a gassers
9/28/02 by yardape 1: RMI-25 broken link
01/18/03 by Powerstroke2000: A quick PH coolant test question...
01/20/03 by Gstar5327: Coolant Voltage
07/17/03 by MADVAN: Coolant Voltage
10/25/03 by Joecephus: How much FW-16?
Has good discussion on mixing SCAs in coolant
*******expect broken links below here*********
02/24/04 by shoebear: <font color="blue">International tech coolant additive comment</font>
<font color="red"> Has post on how long 444 will go w/o damage and no additive</font>
04/13/04 by PSDJOE: <font color="blue">NAPA COOLING SYSTEM TREATMENT #4058 </font>
07/02/04 by merlin1: <font color="blue">Coolant additive, what does it do? </font>
05/12/05 by ontoughdiesel: <font color="blue">HELP Coolant is green!!! </font>
<font color="red"> Discusses adding SCA to Gold Coolant</font>
06/27/05 by duallydog: Coolant Supplements (SCA's) for 05 6.0L?
Has comments on nitrites and testing in the Ford Gold coolant
07/04/5 by jschall: Yellow Coolant PH and Specific Gravity
Good post by an actual coolant test guy on testing errors on the Ford Gold coolant
Cooling system - Filters
8/27/02 by Eltoro2000: Help with Coolant Filter selection!!!!!!
01/12/03 by yardape1: <font color="blue">Coolant filter change?</font>
01/18/03 by pennyjim: <font color="blue"> Installation of coolant filter</font>
03/02/03 by FishAlaska: <font color="blue"> Coolant filter </font>
05/27/03 by tginz: <font color="blue"> Coolant Filter Questions ??? </font>
07/11/03 by Hokum: <font color="blue"> 3/8" coolant hose?</font>
<font color="red">Good links to my coolant hose</font>
02/14/04 by Hokum: <font color="blue"> Fist coolant filter change... an eye-opener! </font>
07/06/04 by NChornet: <font color="blue">Adding coolant filter </font>
07/07/04 by goalie: <font color="blue"> coolant filter with water temp gauge</font>
Cooling system - <font color="red">Flushing/Maintenance</font>
02/07/03 by hank53: <font color="blue"> "T" Used to flush cooing system? </font>
05/19/03 by ElkHuntingNM: <font color="blue"> Cooling system maintenance </font>
07/30/03 by Itchn2Ride: <font color="blue">Coolant Change Help</font>
09/02/03 by DizzyD: <font color="blue"> $0.74 worth of free advice, for what it's worth </font>
<font color="red">Failure of factory clamps discussion</font>
10/17/03 by Glenstr: <font color="blue"> thinking about coolant change this weekend... </font>
11/20/03 by SmokeyWren: <font color="blue"> 100,000 mile cooling system maintenance </font>
<font color="red"> Excellent coolant change discussion</font>
12/03/03 by ProPistols: <font color="blue">Constant Torque Clamps for Radiator hoses?</font>
02/13/04 by Hokum: <font color="blue"> Rad hose clamps </font>
01/24/04 by taters250: <font color="blue">Coolant Flush</font>
03/22/04 by garagedog: <font color="blue">coolant change</font>
04/12/04 by garagedog: <font color="blue">Coolant flush </font>
06/18/04 by Mark Hodowanec: <font color="blue"> Coolant Change Procedure </font>
Cooling system - <font color="red">IH Water Pump install on a PSD</font>
04/06/02 by Renegde : <font color="blue">manleyjt - - need a refresher on the water pump blues </font>
04/20/03 by Renegade: <font color="blue"> IH water pump w filter boss on a 99&amp;up 7.3 </font>
<font color="red">Has pics part # for IH pump swap</font>
01/31/04 by grahmbl: <font color="blue"> Anyone have a write up on the internatioal water pump conv.? </font>
02/23/04 by DaveBey: <font color="blue"> Help Me Double-Check Parts List for International Water Pump Change</font>
03/04/04 by ZilardF250: <font color="blue"> IH water pump, can't keep the belt on.</font>
03/09/04 by DaveBey: <font color="blue"> What Your (Genius) Articles Editor Learned Installing the International Water Pump... </font>
10/24/04 by KCovey: <font color="blue"> Installed International water pump w/ stock belt !!! Pics. </font>
02/14/05 by Numb: <font color="blue"> Waterpump ???'s </font>
02/26/05 by TexTon: <font color="blue">IH water pump - pre-degas bottle hose part #]</font>
02/27/05 by BigRed CC Dually :<font color="blue"> IH Water Pump Hoses </font>
Cooling system - <font color="red">203*T-stat mod</font>
02/22/03 by Menace: <font color="blue">Waiting on Factory Rep (not good) - LONG!</font>
<font color="red">Problems of using wrong thermostat</font>
04/02/03 by Eltoro2000: <font color="blue"> Need opinions on 203 Deg. thermostat on 2002 F-250 </font>
04/14/03 by pwrstrokeme: <font color="blue"> 203 deg thermostat?</font>
04/24/03 by 444turbodiesel: <font color="blue"> Just did the 203 T-stat mod </font>
<font color="red"> 05/04/03 by Larry M:</font><font color="blue"> Actual temps with 203 T-stat</font>
06/20/03 by shesnoisy: <font color="blue"> 203* What the? </font>
06/22/03 by Aceman: <font color="blue"> Evans coolant and 203 degree thermastat</font>
06/22/03 by johnp034: <font color="blue"> 203* Stat and Evans Coolant. 5 Gals?</font>
10/23/03 by Paul_B: <font color="blue">203* t-stat re-install question??? </font>
11/23/03 by RenoF250: <font color="blue">Thermostat Housing Torque </font>
11/27/03 by Flash1034: <font color="blue">Thermostat Housing Leaking---Again...? </font>
01/18/04 by John_Herrera: <font color="blue">203* T-stat and billet housing </font>
<font color="red">Discusses sealant for T-stat housing</font>
01/28/04 by JEEPING: <font color="blue">Pros &amp; Cons of the 203` Tstat? </font>
09/30/04 by PowerstrokeStarr: <font color="blue"> 203* Thermastat Fact or Myth</font>
<font color="red">10/12/04 by Larry M:</font> <font color="blue"> 203* T-stat</font>
Cooling system - <font color="red">General &amp; Misc.</font>
06/19/03 by jwillett: <font color="blue"> Need TSB on coolant and trans fluid please </font>
<font color="red"> Has TSB on which coolant and the Mercon/Mercon V info</font>
06/25/03 by EOD: <font color="blue"> I can hear my Fan..Is this normal?? </font>
<font color="red">06/27/03 by Larry M:</font><font color="blue"> Best Coolant Sensor Location </font>
<font color="red">06/29/03 by Larry M:</font><font color="blue"> Coolant Temp Study</font>
03/04/04 by FloridaEd: <font color="blue"> Water Pump Life/Replacement</font>
07/20/04 by SigsPSD: <font color="blue">water pump replacement?</font>
11/30/04 by Horsecamper: <font color="blue"> COOLANT TEST RESULTS !!</font>
<font color="red">Discusses results and costs of details coolant tests on a 6.0L engine</font>
12/07/04 by RagingMain: <font color="blue"> Acceptable Levels of Oil in Coolant?</font>
12/02/04 by jonDIESEL: <font color="blue"> Add Coolant?</font>
04/02/05 byRazzyB: <font color="blue">Water pump bolt - broke off! </font>
05/17/05 by MarEkberg: k<font color="blue">How do you take the dang fan off?</font>
05/21/05 by EOD: <font color="blue">Water Pump Woes... (kinda long) </font>
07/18/05 by JOAT<font color="blue">Coolant Eye???</font>
<font color="red"> Has post by Bob on coolant eye cracking</font>
CPS
6/18/02 by mjstef: <font color="blue">Best place to get a spare CPS? </font>
7/19/02 by skammer1: <font color="blue">truck intermittently dies...throws SES then keeps going</font>
01/25/03 by FishAlaska: <font color="blue">CPS part number</font>
03/19/03 by DaveBey: <font color="blue"> More Information Than You Ever Wanted On CPS Part Numbers </font>
02/26/04 by DWNRIGR: <font color="blue"> PSD - Quit at stop lights </font>
<font color="red"> Has link to top thread with pics of CPS and how to change</font>
11/23/04 by DBinColo: <font color="blue"> CPS Question </font>
Exhaust
10/10/02 by jdtractorboy: <font color="blue"> Pictures of Walker BTM</font>
02/08/04 by KRMNAL1: <font color="blue"> Help...on Banks Power Elbow install...$#$%^&amp; down pipe</font>
<font color="red">Has info and links on the no crimp exhaust clamps</font>
10/28/04 by dddenio: <font color="blue"> Stock exhaust Drone inside rear of X</font>
02/03/05 by coldair: <font color="blue"> what parts do I need to change the up pipe gaskets? </font>
Larry M is offline   Reply With Quote
