Re: Opinions on K&N intake kit for 5.4L
Last I knew the K&N didn't come with any type of heat shield from the motor. The airaid does, but the airiad kit re-uses the stock tubing, so the K&N has a better and cleaner look. I would just be more comfortable with some kind of enclosure around the filter to block heat from the motor.
Did you notice any power or MPG increases?
2004 F250 CC 4x4. Dark Shadow Grey XLT. 6.0L, Auto, 2" Edge Mini Pack / F350 rear block lift, 295 Toyo AT, 16X8 Centerline Scout wheels, 3.73 LS.
'84 CJ7,TBI I6, SM465, D300, 4.88's, D44/ARB front, 9"/Detroit rear, SOA, 37" MT/R's, OBA, HS9500i.
