Re: Exhaust Brake
three observations
12000# is very near the limit for the F250 so you are at the outer edge of capability on things like brakes etc.
an exhaust brake retards the engine speed to create braking effect. on a std transmission, this is effective because with clutch fully engaged, the drive line is solid from crankshaft to wheels.
for an exhaust brake to work on an automatic where there is normally NOT a solid driveline because of the torque converter, the brake is only going to work if its control features include a torque converter lockup.
This can be done by using tow haul mode on the Torqshift transmission.
I'd first have the trans and PCM checked to insure tow/haul is working. Exh brakes are a $1000-1200 deal plus install. I looked into it briefly and decided against it because I couldn't buy just the brake (alrady have 10gal of 125psi air on board).
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
New Truck
http://www.f150online.com/galleries/....cfm?num=15052
Traded In Nov 07: 2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
http://www.f150online.com/galleries/...w.cfm?num=3016
