misfire on V10...
Tech says intermittent ground from ECM preventing the injector from fueling the cylinders (3 and 5) causing the skip. Only recent repair had a blown plug repaired and needed a new coil pack. That cylinder is firing fine.The Tech says I need a new/used ECM.
Does anyone have a similar experience and what did you do about it?
thanks.
duramax GONE finally
now have a 2005 F450 6.0 dump
had a 2002 3500 Duramax Dump (didn't want it)
have a 94 F350
have a 2001 F350 SC SRW V10
had a 2003 F350 7.3 XLT
Had a 1999 F250 7.3
had a 1995 PS F350 Dump
