Re: misfire on V10...
Thank you for your reply.
What is a COP? I think I know,but want to be sure I understand you.
Also, I really don't know enough about it but doesn't the PCM provide the ground internally (assuming wires to and from are ok), and in turn this "cycling" fires the injectors ?
It was tested with a "node" ? I think that the device has an LED that blinks when the cylinder is to normally fire the injector. I was told #3 and #4 fire intermittently based on the test.
In turn they are telling me it needs a new 'puter.
We are in no rush , I have another vehicle and we haven't found a used one yet.
Any more thoughts? [img]/ubbthreads/images/graemlins/confused.gif[/img]
Thanks.
duramax GONE finally
now have a 2005 F450 6.0 dump
had a 2002 3500 Duramax Dump (didn't want it)
have a 94 F350
have a 2001 F350 SC SRW V10
had a 2003 F350 7.3 XLT
Had a 1999 F250 7.3
had a 1995 PS F350 Dump
