Re: misfire on V10...
Someone probably knows for sure, but I believe I was told the ECM grounds internally , and this cannot be repaired,only replaced with a unit that is compatible with the VIN. Assuming all prior diagnostics were correct to this point.
I really don't know enough about it, that's why someone else is fixing it for me naturally. I spent $450 on the plug repair, and then another $250 on 2 more COP's and more diagnostics to find the skip, so I am trying to find out as much as I can .
I'm at the point where I want the "final" repair done .
Thanks again for the info..
duramax GONE finally
now have a 2005 F450 6.0 dump
had a 2002 3500 Duramax Dump (didn't want it)
have a 94 F350
have a 2001 F350 SC SRW V10
had a 2003 F350 7.3 XLT
Had a 1999 F250 7.3
had a 1995 PS F350 Dump
