Re: misfire on V10...
What does a misfire sound like? I've got a wierd sound/vibration on my 2005 V-10. Almost sounds like a heat shield or other metal component underneath is vibrating. Very intermittent, and only when the truck is rolling (i.e. it is under some degree of load). No codes, and the monkeys at the stealership are content to keep replacing exhaust components. Wondering if this is what I'm seeing.
I recall seeing a TSB that pertained to the issue you are having. IIRC, it directed us to replace the front exhaust pipe with a revised part. I no longer have OASIS access, so I can't look up TSB's to look up specifics, but there may be another tech here who can look it up, or may have a little better memory than what mine is tonight.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
