Re: down pipe
You'll immediately notice a reduction in EGTs - even with your cat intact and in place.
One thing you might want to take into account: The OEM DP is a double-walled tube. When you replace it with a single wall tube, you get more turbo whine inside the vehicle.
It may just be a van thing - the turbine sits about seven inches away from the passenger's left knee. I'm going to wrap my DP with header wrap and see if that helps.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red"> DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350 XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
