Re: 97 Front Spring Conversion to SD???
But I think I like Shannon's version although I think lowering it could be dealt with by installing a block to raise it up again, not sure.
NO! Absolutely not. Blocks are for the rear, not the front. If you want to lift with Shannon's version, use a longer shackle. This might require moving the perch to keep the shackle position correct, but much safer than using a block on the front.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07: DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
