Re: 1997 cheap door handles?
your door handels brake becuase of the actual mechanism that unlocks your door from your handel. it is probably worn out or the sheet metal around it is cracked and allowing free play making it bind and that makes you break your handle. take the time... open your door up... look around and if need be tac weld the metal up and buy a new mechanism. it will save you money and fusteration in the long run.
1997 Ford F-250 HD XLT Powerstroke diesel, Tymar intake, Stancor GPR
