head studs are in
well got them all in last night. i must say if you have a plasma cutter it is much easier to cut a hole in the firewall instead of tilting the cab [img]/ubbthreads/images/graemlins/smokin.gif[/img]. now as soon as i get another h2e i will be good to go. i started working on the intercooler also and a ? do you really HAVE to take all the stuff off the front end? thanks
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
