Re: Blowing fuse number 28 on the underdash panel
If it's popping everytime you put a fuse into the panel then more than likely you've got a wire shorted somewhere. I'd be tracking wire runs looking for some place that the insulation has come off the wire or that the wire is pinched. You might also look at the plugs to make sure something isn't shorting across them. (on whatever connectors you're using for the plow)
Just my .02
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
