Re: Rear End
I would love an overdrive unit, but that's way out of my price range. I would think I could get rearend changed for a lot less than an overdrive would cost. I'm guessing I could get the rearend and the flatbed for what the overdrive would cost.
Johndeerebones, how many rpm are you running at 70 mph?
You are right depending on how good you are at dealing.
My speedo is a few percent off, but at 770 in OD I am running a little over 2000 rpm's.
For a comparison on a hard acceleration run I can run 65 in third before the rpms scare me, but I'm pretty brave on the tach [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Oh, I also run 265-75 tires, so a little taller than stock..
I get my best mileage at 65 and down, but you get run over on the highway around here at that.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB  DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
