Re: Knocking noise...ugh!
Spook,
When you did the Jack-it kit, did you use the almost half bolt with the eccentric washers in the upper trac bar bracket?? If you did, that is what's causing it. I called Jack-it and they admitted to me that this was a problem. They gave me full credit on that upper bracket. The only way they said it would stop is by going with an adjustable trac bar which would eliminate the half bolt and eccentric washers. That was straight from the horses mouth...
Rev
2008 F450 SD Crew Cab,4x4,Dually, King Ranch, Lariat, 6.4, 4.88's
